markfh
Ok, I replaced all my brake system from master cylinder to the brake cylinders. All new preformed lines, both proportional valves, the works. In trying to bleed the lines I find that I have leaks. The line to the rear axle leaks at the proportional valve. The line from the proportioning valve across the firewall leaks on both ends, and badly.
I thought I didn't tighten them enough so for those that leaked I eventually tightened them as much as I could and they still leaked.
Any ideas? I'm at whits end on these and about to replace everything again, from someone else this time.
