I am contemplating a cam swap on my 67 273 Commando Barracuda S. My plans are for a 625 Carter (or EFI), Performer intake, adjustable 1.6 roller tip rockers, headers, full dual exhaust with h pipe to accompany the cam change. In looking at the different cam companies Lunati sticks out to me as a good looking grind. It is thier Voodoo flat tappet 262/268 cam:
Advertised Duration (Int/Exh): 262/268
Duration @ .050 (Int/Exh): 220/226
Gross Valve Lift (Int/Exh): .475/.494
LSA/ICL: 112/108
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1400-5800
Has anyone used this cam in something similar? Will it "wake up" my 273 or will leaving the stock cam in place with these other mods be enough? I guess something approaching 300hp with decent low end (With a 273?) and daily drivable would be my dream.
:violent1:
LSA/ICL: 112/108
:violent1:
