MarcD
Active Member
Installing carpet in my '63 Dart GT; the interior was pretty gutted when I bought the car, so I have no frame of reference for how the carpet fits at the accelerator pedal. Search of this forum yielded a helpful post about carpet interfering with WOT, but not the issue I'll describe below.
The pedal pivots from the bottom on a pin through a u-shaped bracket fastened by two bolts through the floorpan. Should the carpet be cut with two slits and installed over the bracket so the two ends of the "u" protrude, and replace the pedal? Seems like it might be pretty tight. Cutting out the entire area around the bracket could look pretty messy.
The other option would be to remove the u-shaped bracket, install the carpet, then bolt the bracket on top of the carpet. Looks like the rubber at the base of the pedal would conceal the bracket and attaching bolts.
The carpet kit is from ACC, by the way, and I ordered the extra mass backing. Very good looking carpet, and the heat-molding for the four-speed hump is really nice.
Thanks for a great forum!
