Diggin through my fan collection recently to take some pictures for another member, I found a couple I forgot I had. One was an older version of the MP viscous fan package, that's been sold and then there was this too. It's a Hayden clutch fan and a new heavy duty fan clutch. It's obviously not the MP unit, but it will work well if you're looking for a clutch fan. Only thing is, you'll need some room because it's a little thicker then the MP unit. As you can see though, you could trim about a good 1/2 off the front of the fins on the clutch before you get to the bimetal sprAng. I've done it before with no problem. It's not like it doesn't have a ton of fins left. Also, the clutch does have the Mopar pattern, as I checked it against an old Mopar unit. Both of these are NEW and never run. $150 shipped to the lower 48. Thank you drive through.
