New clutch setup won't disengage
I have read that entire thread last month and wasn't impressed with the repartee, and neither were the moderators as I recall...
[EmilyLitella]never mind![/EmilyLitella]
Well, some day when I get software that will type what I say, I may do a tech article on pressure plates, discs, FW weight and tuning buy ain't no way I'm going to type it all.
@yellow rose , hey bud , your a clutch guy ? if so maybe we need to talk , like you said typing is a thousand words is for the birds . pm me i'd rather talk on the phone if you would . my quest is a 10'' clutch setup behind my 340 6pck in a 64 cuda 4spd of course an a833 .
I'll ask one more time, since I can't easily measure plate departure, does anyone know how far the fork tip must travel to disengage the clutch??
Thanks!
1/2 an inch from zero freeplay, between the clutch fork and the pressure plate fingers, at the throw out bearing. Per McLeod tech line.
I appreciate the help, but that is still not what I wanted to know ;) I don't know how else to say it - how far does the clutch rod have to move the fork?
However, I got the answer a long time ago by asking Centerforce directly. Their reply:
The disc will be released with an 0.030” air gap. Linear travel at the bearing is 3/8” to release. Bearing load is 500 lbs.​
Then I contacted Brewer's to ask what the ratio of the fork is:
Center of pivot point to center of clutch bearing 3.25"
Center of pivot point to center of clutch linkage eyelet 6.5"
That would be a 2:1 ratio.​
So - with the free play taken up. 3/8" * 2 = 3/4" movement at the original fork actuating rod hole.
I haven't been underneath in a while, but I found that a little more movement was better for full disengagement.
:thumbsup:
I’ve had trouble with clutch release on a few Moparts of mine over the years. Especially using Hd Zoom, Schaffer etc. Biggest issue I found was clutch linkage flex.
:thumbsup:
It makes a difference which pressure plate you are using, as they all have different lever ratios. In fact, my cover uses a custom made lever that Cale Aronson uses with the B&B/Long cover.
Also, the ratio of the bell crank can be changed which will make a difference.
YR, that is all true, of course, but not applicable to my original post when I started this thread back in 2016:
I have a Centerforce Dual Friction clutch setup on a new 10.5" steel flywheel. I fabricated a hydraulic linkage with a Wilwood master and a pull-type slave cylinder to a conventional fork/throwout bearing.
:p
And there is also a "bellcrank" ratio to factor in, dependent on the bore sizes of the master and slave cylinders. :D
