CAMOPARS
For sale is a NEW Comp Cams SB Mechanical Solid Roller Cam. I had it nitride coated when I had my solids coated. Specs are as follows:
COMPETITION CAMS PART NUMBER: 20-752-9
ENGINE: CRS 288AR-6
GRIND #: CRS 288AR-6
INT EXH
VALVE ADJUSTMENT: .020 .022
GROSS VALVE LIFT: .631 .630
DURATION AT
.020 TAPPET LIFT 288 296
VALVE TIMING OPEN CLOSE
AT .050 INT 20 52
EXH 55 23
THESE SPECS ARE FOR CAM INSTALLED
@ 106.0 INT C/L
INT EXH
DUR @.050: 252 258
LOBE LIFT: .4210 .4200
LOBE SEPARATION: 106.0
RECOMMENDED CC VALVE SPRINGS: 943-16
Summit Link: http://www.summitracing.com/parts/cca-20-752-9
Located in San Jose, CA. Cost: $330. Asking: $275/BO + SH (or pick up for free)
ENGINE: CRS 288AR-6
INT EXH
DURATION AT
AT .050 INT 20 52
EXH 55 23
@ 106.0 INT C/L
INT EXH
DUR @.050: 252 258
