[SOLD] NEW Comp Cams SB Solid Roller Cam
CAMOPARS
CA
For sale is a NEW Comp Cams SB Mechanical Solid Roller Cam. I had it nitride coated when I had my solids coated. Specs are as follows:
COMPETITION CAMS PART NUMBER: 20-752-9
ENGINE: CRS 288AR-6
GRIND #: CRS 288AR-6
INT EXH
VALVE ADJUSTMENT: .020 .022
GROSS VALVE LIFT: .631 .630
DURATION AT
.020 TAPPET LIFT 288 296
VALVE TIMING OPEN CLOSE
AT .050 INT 20 52
EXH 55 23
THESE SPECS ARE FOR CAM INSTALLED
@ 106.0 INT C/L
INT EXH
DUR @.050: 252 258
LOBE LIFT: .4210 .4200
LOBE SEPARATION: 106.0
RECOMMENDED CC VALVE SPRINGS: 943-16
Summit Link: http://www.summitracing.com/parts/cca-20-752-9
Located in San Jose, CA. Cost: $330. Asking: $275/BO + SH (or pick up for free)
Additional info: this is a billet (not cast) camshaft. It was nitride coated along with some solids I had coated. The actual cost of this cam was $330 for the cam and $105 for the nitride coating for a total of $435. Selling for $250/Bo.
Someone is getting a heck of a deal here. Nice cam!
Thanks. It is a screaming deal. :cheers:
Yeah that's so ridiculously close to the same specs as the cam I ordered a month ago that I would have snatched this one up in a hearbeat if the timing had been right.
