[SOLD] New Edelbrock EFI complete kit with 340 intake and distributor
Killswitch
Active Member
Eastern PA
I have a new complete Edelbrock E-Street 2 EFI kit 36659 with return style pump kit, Edelbrock RPM air gap intake, Mallory Unilite Distributor.
The EFI and fuel system is new in box never opened.
The intake manifold was used to break-in cam only.
The distributor was use used to break-in cam only as well.
Intake and distributor still on engine. I will take pictures and get all part numbers when I get back to the shop this weekend.
$1,300 for all, not looking to separate at this time.
Located NE Philadelphia, Pa
Link to Jegs site for EFI parts photo
EFI is still in the box unopened as seen in photos. I just tore a window in the box to see the product packaging.
Strange. The wires coming out of the housing LOOK Unilite, but the side of the distributor says magnetic. They are not the same. Hmmmmmm
Ok I did some checking. That particular distributor is a magnetic pick up but uses the three wire style hook up like a Unilte.
So technically it's not a Unilite. Great distributor.
Yeah, not sure why I typed Unilite.
This is from Summit:
Brand: Mallory Ignition
Manufacturer's Part Number: 4257911
Part Type: Distributors
Product Line: Mallory Comp S/S 42 Series Distributors
Summit Racing Part Number: MAA-4257911
UPC: 769105120913
Computer-Controlled Compatible: No
Trigger Style: Magnetic
Advance Type: Vacuum and mechanical
Cap Style: Male/HEI
Mechanical Tach Drive: No
Slip Collar: No
Ignition Box Required: No
Distributor Gear Rotation: Standard
Distributor Cap Color: Red
Housing Material: Billet aluminum
Housing Finish: Natural
Marine Use: No
Quantity: Sold individually.
Notes: Includes vacuum advance eliminator plate.
In-Store Pickup: Choose In-store pick-up (OH, NV, GA, TX) on our web site.
These Mallory Comp S/S 42 Series distributors are designed to give your ignition system a boost.
They feature the following:
* CNC-machined billet aluminum housing
* Ball bearing upper and lower bushings for maximum stability at high rpm
* 208 Series distributor cap with spark plug wire retainer
* Ready to run
* Easy-to-adjust mechanical advance
* Vacuum advance with vacuum advance eliminator kit
Put me in line behind 68GTCovert please.
Just to clarify, Can I use this EFI system with this MSD Distributor?
The reason I ask is this doesn't have vacuum advance. Not sure I need it for the EFI.
MSD Billet Distributors 8534
or do I need a RTR setup
MSD Pro-Billet Ready-To-Run Distributors 8360
The 8534 requires an ignition box which is recommended to use by most EFI manufactures including Edelbrock. So yes MSD 8534 can be used. You can run an RTR with or without a CDI box. The kit also comes with an adapter to run points ignition.
I plan to run the 8534 with a 6AL box. Thanks for the info.
Let me if it gets to me please.
