New EQ Head port misalignment?
The video 318willrun made about this is getting posted on a 318/5.9 Magnum FB group. Possibly other groups too. I hope every will know to not buy this brand.
Finally got my block back from the machine shop and mocked everything up. Everything looks as it should with port placement with these "good" Promaxx heads. The ceiling of the port is basically line-to-line with the intake on the two ports I could barely see. I can barely get in there with my eyeball with the intakes I have so I can't really get a picture.
I could inevitably see if you had the other "bad" casting how the port would mismatch the intake.
Curious if anyone could mock up onto a block to confirm.
Measure the deck surface to the bolt holes. That will tell you if the holes are wrong. You can find measurements of LA heads earlier in this thread.
I have LA heads I can compare. when I get the time .. lol
WOW , those head need a bunch of rework , so glad my eddy heads are right on port to bolt mounting locations , a friend built a big inch caddy motor , and had several pairs of heads that where machined wrong , from water jacks leaks to completely off mounting holes . he finally got a pair that worked and that thing is a monster of torque .
