The motor and trans are out of it. They were pulled out around 85 or 86. It is a 69 340 with a 480 lift hyd. cam. The trans is a e body hemi 4 speed with a pistal grip shifter. The motor was pulled to go in a front engined 185" dragster. I was bracket racing the barracuda and was running low 12's and wanted to go faster so I found the dragster frame and started racing it instead. In the dragster with the barracuda motor it went low 10's. I then built a little bit hotter 340 and went a best of 9.08 at 150. I kept all of the barracuda pieces and now have the time to put it back together. Not a restoration, just putting it back mostly like it was when I first got it.
