Xela.zue
Member
hi all,
I'm new to the forum but not to mopars, My dad and I have been restoring a 67 dart gt for the last 10 years... slowly but surely. Recently the gas and temp gauge quit working and after looking on this and other mopar forums, we went through the test steps recommended and came to the conclusion it was the IVR. We replaced it today and it seems like it sort of worked. The instrument cluster is out and resting on the steering column where we connected all the plugs, hooked up the battery and turned on the ignition. The fuel gauge slowly moves and stops at half a tank which is pretty close. The temp gauge pegs all the way to the right so there's an issue there. After spending an hour trying to figure out what was causing the temp gauge to malfunction, we gave up and decided to do without it for now (we have an aftermarket mechanical gauge set up). We placed the cluster in position and before placing the holding screws gave it another check... there's something contacting the housing because there's an audible clicking and now the fuel gauge isn't working. How can it be it works outside the dash but not inside? And what can be making contact causing a short? I tried taping the studs behind the gauges, the back of the ivr and the speedo thread just to narrow it down and I'm still getting the short
