*NEW* MOPAR Hydraulic Roller Lifters
MRL Performance
here
Here are our *NEW* Hydraulic Roller Retrofit Lifters. They are a drop in fit for any SBM/BBM/HEMI. Made from the highest quality components and are a GREAT lifter for the Steet/Strip budget minded racer. they are budget priced, but not budget quality!
The quality of these lifters is far and above anything in their price range, and are as good or Better than other retro-fit lifters coasting Hundred$ more!
We have been thru our final re-design and dyno tested them on BBM and SBM with stellar results! No issues at all going to the high RPM, 6500rpm. these lifters were tested on some of the most aggressive hydraulic roller profiles, and they passed with flying colors.
They oil thru the pushrods if you need to run that type of rocker system.
Intro Priced for $375 a set for any engine.
PM me and Ask about our Special Cam/Lifter packages!
Made in the USA
..................Another great product from MRL...................Kim............
yep.....if only he was not so far away he would be the one to build my motor......if i ever get to it that is......
Here is an engine running our lifters. Made a lot of pulls from 3500-6300rpm. Performed well. Cam was a Lunati Voodoo 243/251 duration with .560" lift
This little 340 stroker made 517HP 510TQ w/M1 knock off from the 80's
[ame="http://youtu.be/PcbCKfwfy-s"]302 Found[/ame]
