How Bad Did Mopar’s 340 beat Ford & Chevy? Shocking New Data! - Hot Rod Network
just wondering peoples thoughts on their article.
Yeah, to be frank, they are underselling the impact of the bowl cut, stainless valves, & rockers on the output. But, it is a standard updated style rebuild w/a relatively smallGood read. I'd say they picked up a little power with quality machine work, the bowl cut, roller rockers with the correct ratio and the 40 ounces they took out of the rotating assembly.
No surprise here the 340 was always under-rated except to those who own them..and here is a perfect example of why to run headers they picked up 32 h.p. by just swapping out the factory exhaust manifolds..I've always said 340's rule!!!
The factory didn't test with all that crap until they switched from gross hp to net hp in '72.did the factory test with an air filter, fan, mufflers, alternator, fuel pump-about 30 hp
