New Sniper EFI decisions
clementine
Flight risk
Emerald city
Well Christmas came early. I got the sniper efi and hyperspark dizzy. Got the motor in the car and took the lift plate off the Holley street dominator intake and....... it's a spreadbore.... not a big deal exept i ordered a square bore body. So, what would FABO do? Return and get correct? Run adapter if you had the height? If you had the height whats the minimum distance you would run the body to the hood for proper air intake. Or.... change intake?
Thanks FABO!
Its not a big deal to return. Just askin.
Edit..... any reason i can't just run a 4150 on this spreadbore intake? Everything seems to clear just fine....if you are smiling and saying to yourself "of course you can dummy" its ok.... just say that, cause then i can move on with life in general. Run a 4150 gasket. Or spreadbore gasket?
It'll be fine - just run this: Carb Adapter #2732 for Edelbrock Manifolds Only, Square Bore-Spread Bore .100in
