mase
Member
Recentley i swapped the heads, intake and carburetor on my 318. after which the engine has started backfiring out of the intake when its in gear and i give it "too much" throttle ( too much being about 2 mph faster than a granny)..since then i have replaced the following: spark plugs, plug wires, distributor cap, rotor button, ballast resistor, coil and had the carb taken apart and inspected. But it still backfires! everybody at the shop i work at is at a loss as to what it could be..Any suggestions?
