Welcome to the best A-body site around. If you don't have that 273 yet, let me give you some advise...look for a 360 and save some headaches and probably a bit of $, you will have better stock power and if you want to build it up later, well the sky is the limit, while with a 273 your max power is in the 300 HP range unless you spend a small fortune.
