Nice kelsey hayes disc set up
superdart426
Banned
NEWARK,DELAWARE
Nice kelsey hays disc brake set up nice rotors,new pads and calipers my need a seal kit from sitting asking 425.00 plus shipping
given the timming, I am buying a set of disc for my front breaks, I have to pay for the booster, master cyl. and a wipper motor next week, so that check is gone, the following week I pay for the disc brakes. but the week after that I could buy these. If you can hang on to them.
dumb question, what would i need to put these on my 70 dart? it has a /6 so its got 9" drums.
New lower ball joints and a disc/drum master cylinder and I think that is it if everything else is there
These brakes may need a disk brake spindle and lower ball joint to be installed on a drum brake pre 73 Abody
The one set I resealed needed all new pistons in addition to the seals.
Great upgrade to a pre 72 abody if you want to keep the small bolt pattern.
Good luck with the sale.
You need a proportion valve,DB spindles, Lower ball Joints and a Dbrake master. Your UCA and upper ball joints should be fine. I'm just about to do this swap on my 65.
are those from an a-body? sure look big bolt in the pics.. early c-bodies had 4 piston brakes too.
The 65 C-bodies first offered disc brakes, not 1966's. These were the 4-piston Lockeed, non-floating brakes, like Corvettes. 1969-1972 were single-piston floating caliper brakes and used both the one piece and two piece rotors. Most of the ones I've seen were two piece.
http://www.houstonmopars.org/brakes.html
