Good stock engine internals,a good fuel & electronic ignition system,100-125 hit safely(premium pump gas,2 degrees total timing backed off ,every 50 h.p. worth of hit. Here's a question to you: how's your drive train & suspension? N20 hammers with a torque spike across the majority of the power band,especially low and mid range. A stock ,worn out chassis on old crusty tires,will frustrate you. Be prepared and ready for it,ask questions .
