moparbros
Active Member
Hi all. I have a complete nitrous set up I took off my 318. I purchased the car with it so I don't know much about it. I never used it either. The guy I purchased the car from said it was a 200 shot or 250. The plate sits under the carb and the switch is located on the carb linkage and is activated when the throttle is wide open. The sale includes the entire under hood set up and bottle with heater and cover along with all brackets and stainless line from bottle to intake. Everything is there that is needed to bolt on and use. I also have a Holley electric fuel pump with less then 5 hours time on it and the regulator. I will post pictures very soon. located in north jersey area 07405. $ 375.00
