harvenator
A fish called Wanda
The previious owner of my 65 Barracuda removed the ballast resistor and wired the start and run wires under the dash together. He installed a NAPA Echlin gold box ecu and retained the stock coil.
This system seemed to work well for the /6 but not for the 273 I built and installed.
I'm currently using a ProForm dizzy with a coil that does NOT require a ballast resistor, initial of 10 deg and no vacuum advance (still playing with the adjustment to make that work). Seems that after I drive for about 20 mins (engine temp about 190), I lose power in the 3000 and up rpm range and the coil seems to be pretty hot.
I've checked the carb and filter for trash and obstructions with nothing noted.
At this point I'm not sure what to do so I figured I'd put this to the forum and see what has worked for others with the same set up. I'm limited on what I can spend otherwise I would have gone with a Pertronix system.
Anyone??
Anyone??
