SirDan
Just focusing on getting the motor to crank over not worried about starting. I recently painted my engine bay and had everything apart and I also swapped to a 4 speed at the same time. Lots of things to get messed up.
Rite now I have everything electrical hooked back up. I put the battery in and the trunk light, horn and flashers work but couldn't get it to crank. Tried jumping out the nuetral saftey switch by grounding it but that did not help anything.
Is one of the under dash fuses for ignition? any suggestions?
