Rob
No brake lights, signals or headlights? Any thoughts? I was thinking a fuse but wouldn't that be several fuses? What are the odds of that :munky2:
Only one screw holding the fuse box up. There is enough slck in the wiring to rotate it vertical.
Well it's a start but I would wonder what blew the fuses. They don't blow for no reason, only when you're pulling more current than they are rated for. If you temporarily shorted something it may explain the bad fuses otherwise you need to find the problem.
