coyote42
Just put my 88 318 together. Still on stand. Was a roller block now has hydrolic flat cam. When priming the oil pump I found no oil at the pass head rockers. Lots of oil everywhere else. Removed pass side rockers. Removed pass side head. Port is clear. Ran drill for pump. No oil. Removed front cover and cam. Inspected cam bearings. All holes in position. Put wire through block to cam hole. Clear. Ran drill on pump. Oil comes out the cam hole on bottom. Checked all galley plugs. Reinstalled cam, head, lifters, pushrods and rockers. Ran pump still no oil an pass side. Tons of oil on drivers side and lifters. Any thoughts? Help!
