Priming my new build and I am not getting oil to the rockers or sending unit .
Engine is a magnum based 408.
Lifter galley plugs ( including the one in front of intermediate shaft ) are installed front and rear . Plug above rear main is in . Plug under oil filter is in .
Oil filter filled with oil while priming.
Turning the priming shaft with 1/2” drill clockwise.
I loosened the plug I used to cap the sending unit galley to allow air out ( I knew that was unlikely) and oil to seep out without coating my ceiling with oil. Turned engine over by hand while priming even though it pushrod oiled .
What am I overlooking?
I didn’t fill the pump with oil but it worked fine before the rebuild and the filter was full so it’s obviously drawing oil..
Head scratcher !
Head scratcher !
