No press? No problem!
Joseph James
Active Member
Asheville, NC
Rear wheel bearing fail. Lots of squeak and fluid leak.
I used a 4” grinder to cut the collar and bearing. Laid a pipe wrench over the new bearing and collar and tapped it on with a small ball and peen hammer.
All that’s left now is the oil seal change and check differential fluid.
First rear wheel bearing job on old Mopar I have ever done. A lot easier than I thought it would be.
Removing the collar seems to be the biggest pain of the whole job.
Nice work!
I screwed up and put the gorilla on the flange nuts. I broke one bolt. Haven’t looked to see if they are available. Otherwise, car is back together. Back to being a daily.
