No reverse, seems stuck in a forward gear
Finally got my kit in today. All the new seals and parts are in, air tested good, bands adjusted, inside douched. All back together, and then I snapped off the pivot pin for the kickdown bellcrank... It was loose and I went to tighten it, my pan bolt are tighter than this thing was when it broke!
First time ever that an easy out has worked for me. Tomorrow I'll try to tap the remnant for a stud and see if I can get it mounted back up.
Mine started doing this today. Never disconnected the kickdown linkage and it is rigged correctly. I think when I went from 1st to 2nd while burning out is what caused it.
