44070dart
How the hell did I get this old..
- Joined
- Jul 9, 2004
- Messages
- 2,679
- Reaction score
- 3,311
- Location
- right here ...see me I'm waving.. NY
Battery full, new relay, no power at the key ignition wire at the relay with key on .. can jump start at the relay and it runs.. if I put 12 v power to the relay ignition terminal and jump the terminals and it runs ?? is there a disconnect switch on the column ? ..thanks Never mind, no ground at the ground terminal wire.... power at the ignition switch WHILE cranking ..missed the cranking part not just power on.... !! .. so I guess the neutral safety switch is shot .. Can't delete for some reason.
