to test the ignition system, unhook the two wire connector from the distributor and unhook the coil wire from the distributor cap.......hold the coil wire about a 1/4" from a ground and while the ignition is in the on position touch the male end of the distributor lead on another ground the coil should send out a spark...if it does not then the problem is in the ignition system and the distributor is ok....this was a "shocking" accidental learning experience
