Non-AC 340 crank pulley number?
Tad
Not here
Running a non-AC water pump pulley number 29518-36. What is the correct number crank pulley for a non-AC car? I have a couple but can’t figure out which one is for a 71 340 crank non-ac
the correct pulley is the one with : one groove w/o power steering , two grooves with power steering . the crank diameter is the same size as the water pump pulley . 318 is the same
Ok, I have the water pump pulley. I found a one groove crank pulley but the offset is less so the belt won’t line up. I was trying to put a slightly larger crank pulley on to increase the speed of the water pump to cool better.
