mopowers
I'm having a brain fart. What years were 46RH transmissions available in non-lock up versions? Was it like 91-93, or something?
Thank you! I'm on the lookout for one for my '68 Dart. I understand I can use the converter out of my existing 727 in a non-lockup 46rh/A518, correct?At least thru the end of the D/W series trucks (93) and I think longer on some Cummins trucks.
Pretty sure he meant A518 since that's what this thread is about. Thank for the info though.Not quite. I know that at least as far as A500s go they did make L/U versions in 90 and 91 at least....
My 90 Dakota had one (3.9) and the 91 I parted out last summer (LA318 TBI) had aL/U... I still have that trans here ...
Yes I did mean 518. KimPretty sure he meant A518 since that's what this thread is about. Thank for the info though.
I think I have a couple prospects on a non-lockup 518/46RH.
Why do you so many of them? How does your buddy like his?The A518 out of my 91 B300 van is a non-lockup 2-pin unit. It is now in my buddy's 70 Cuda vert behind a 340. I'm also always looking for some more of those. I have a couple 3-pins units.
You're probably right. Maybe it's regional thing too. Hell, the transmissions at pick-n-pull around here are pushing $300 out the door these days.The ole “I know what I got….” syndrome. For that kind of money it had best be CLEAN inside, no failed hard parts.
