edbux
My daughter bought a 1993 Ford Taurus. We had looked at it and I suggest she not buy it. While at work, the lady called and said she had a couple of interested parties but because my daughter was young...long story short, her and her mom went and bought it.
Day 3 of ownership, the water pump started leaking thru the weep hole. Easy enough replacement in spite of tight quarters. 2 days later after warming up, it sounds like the engine is a diesel when idling. As soon as you give it gas, it goes away. No dummy lights are turning on. Check and verified the sensors I could.
Anyone have an idea what this could be? I'm hoping it isn't the oil pump. Oil is full and was changed before the water pump went south. I hate to see here spend a lot of money on this things, she is starting at Boise State this August. I'm proud of myself because I have resisted uttering "I told you not to get it". It's also going to need valve cover gaskets and a power steering pump, which is going to be difficult because you have to yank the pulley off to get to the bolts and it looks like it requires a special puller due to clearance issues. I think I can rig something up for that.
Thanks for any assistance!!!!
