[WANTED] Norris Stainless Steel Roller Rockers
Atilla the Hund
New Member
Berthoud, CO
Rating - 0%
0   0   0
I'm on the hunt for a set of Norris Stainless Steel Roller Rockers for my 340 R1 block with W2 heads. Picture provided for reference. Please note the near 0 offset for exhaust and approx. .775 offset for intake.
Any and all leads are appreciated.
My understanding was that Norris is still in business, but on a very small scale, like out of his home garage. You might try searching the net for some contact info. It's worth a shot.
Thanks for that. I had heard similar in other places including reaching out to a "phone number" (714)752-3766. This number belongs to "Kaddie Shack," a vintage VW hotrod shop in Pasadena, CA. Research shows that there was some connection between Kaddie Shack and Norris at one point but that Norris is no longer in business.
Norris Cams/Camshafts & Performance Products for VW's
I finally got ahold of someone at this number, at Kaddie Shack. They said they couldn't help me and that I should look on eBay.
Back to the drawing board... :-(
Have you tried Gary at Rocker Arms Unlimited? He might have some.
I called Gary, thank you. He doesn’t have the Norris rockers but does have the OEM ductile iron rockers which are my second choice. If I can’t find some Norris, I’ll go with the OEM rockers.
The search continues… :-(
I tell you, those 273 rockers are the shizzle. They can take a ton of abuse.
