[SOLD] NOS Holley Water Injection
Fast01
Farmingville, N.Y.
Another something I had to have, had grand plans for and never used! I have an old Holley water injection system. It's quite old, but it's never so much as had water near it. It's supposed to inject water to reduce or eliminate detonation automatically based on engine vacuum and temperature. This kit has a 6" vacuum switch. What got my gears turning over it was the fact that it can inject alcohol instead of water or a mixture of alcohol and water which as we all know can be used as a performance "enhancer". In fact, the paperwork recommends a water/alcohol mix in "cold" weather to prevent the reservoir from freezing. Anyway, it's a complete kit and I hope someone can take it off my hands and put it to good use! Figure $50 plus the ride. Oh yeah, I have a brand new spare pump to go with it.
That is interesting....adaptable from a windshield washer pump? Hmm......
Why not just pull the hose off the windshield squirters and stick it in the air cleaner at least you will get some alcohol
It appear to be a little more sophisticated than that, with coolant sensor, oil pressure sensor, vacuum switch, and metering valve.
