NOS parts wanted!
65dartcharger
Dart Charger 273 Historian
Tavelsjo, Sweden
Locking for the following NOS parts for 1965 Dart;
Front end parts
2 x 2071650-1 Steering knuckle
2 x 2072437 Adju tube w/clamps
2 x 2462578 Bumper, lower control arm
2 x 1858024 Bushing, lower inner
2 x 2298533 Ball joint, upper
2 x 2084920 Cam & bushing pkg
2 x 1825314 Bumper frame
2 x 2071173 Seal, front spring rear end anchor
1 x 1858262-3 Shield, steering link outer tie rod end seal
Brakes
2 x 2534850 Front front brake shoe
2 x 2534853 Front rear brake shoe
2 x 2534856 Rear front brake shoe
2 x 2534859 Rear rear brake shoe
2 x 2534758 Lever right
2 x 2534759 Lever left
4 x 2534760 Spring, lower
4 x 2267044 Spring, upper , front shoe
4 x 2260835 Spring, upper, rear shoe
2 x 2260572 Nut, right adj sleeve
2 x 2260573 Nut, left adj sleeve
4 x 2260824 Socket, adj screw
2 x 2460654 Screw, right adj
2 x 2460655 Screw, left adj
4 x 2401513 Cable adj
4 x 2260793 Guide cable
4 x 2267045 Plate, upper
2 x 2266890 Seal knuckle
Any of these parts must be in mint condition. Buy or trades for other early A-body parts. Thanks in advance
I found some stuff in my basement and was wondering if you got all your front end parts. I have original equipment stuff. Please let me know. Thanks.
Frank Mitchell gets not one cent of my money. He is a con artist, a cheat, and a fraudster.
(Also: NOS brake shoes…? I'm sure you can find them, but isn't that a little…extreme?)
Can you expound on that? I mean, it wouldn't surprise me. I've always known his prices were astronomical, but he HAS the inventory. I've not heard that he was dishonest. Inquiring minds wanna know.
I have friends that have been ripped off by this guy. Very few names are known nationally for this, but Mr Mitchell seems to have quite the reputation. Buyer Beware!!
See here. If you happen not to get screwed, you're good to go, but he's screwed enough people enough times over the years that his "never again, no matter if he's the last and only source" quotient is uncomfortably high. I don't like to support vendors like this.
And that's without even going into his tactics at swap meets. More than once I've seen him and his assistants hover over tables, literally take parts out of the hand of a buyer reaching for his wallet, throw money on the table and walk away with the part. That's just not okeh with me.
Dan, thanks for that. I knew if you had a problem with him, there was substance to it. Thanks again. And to the OP, I apologize for making that recommendation. Use your own judgement.
