twayne24365
ok fellas, here's the run down...
Fairly new battery in the trunk
One wire 63amp alternator
Msd6al ignition
And really the only electrical accessory is a fuel pump.
I had to replace the alternator due to a bad bearing, used to show 14volts with key on, then 12 volts while running. The replacement alternator shows a constant 10.5 volts with key on and while running, any ideas? I'm no electrical guru haha
Thanks!
Msd6al ignition
Thanks!
