Hello all - I recently got my 64 Dodge Dart with a nearly completely dead battery. I checked while running and the alternator was from 1983 and did not appear to be working. Voltage regulator was also very old.
I swapped the alternator (tested good) and voltage regulator and still can't get it to charge. The wiring is sure odd.....
The FLD terminal is going into a loom back towards the firewall, all the way across to the right, past the battery, back around front by the radiator and into the negative of the HORN. WTH??
The Positive or Charge cable - it goes into the same loom but I can't quite tell where it goes. It may stop at the ballast resistor or somewhere else.
I checked continuity to positive for the Charge cable - all good. FLD cable is continuous with Ground /Negative.
Any clue as to why it's not charging? The Chilton's book I have says that FLD should go straight to the regulator but I can't tell if that's what's happening already.
