Rodzilla
Installed my 489 case with brand new Auburn sure-grip and 4.30:1 gears. Spend several hrs on my Wilwood instructions installing disk brakes and axel on passenger side. Confused at first cause tard who installed bearing put the original retainer ring on axle, luckily with the snap ring stylegreen bearings you can get that off. So I get the passenger side all finished and buttoned up, leaving the drivers side fot the next day. Thinking now I know what I'm doing it should be a cinch to finish up the job,,,,BUT no! My "stock" length replacement Moser axles are to frigging long! So I cant get the drivers side in all the way, about 3/8" short. NOT happy!! I ordered these axles from Bill Reilly along with my Street Lynx 4-link and my AlterKtion. I never came across anything in the instructions about needing to leave out the center spacer in the diff so axles would fit. I already have the flippin rear end all sealed up, axle retainer and caliper on passenger side RED loctited as per instructions. My only option to not disassemble is to cut the drivers side axle down, leaving me with barely an inch of spline inserted into the diff, I'm sure thats not good. Friggin pissed about this,,,,rant over!!
