draginmopars
we are building a street /strip more door 70 Dart
Gayle wants to race (at track only)
using a 340-4 block date 6-23-70
after cleaning the cosmoline off,
Then sonic checking the cylinders
started chasing/cleaning the bolt holes
OOPS, that isn't a bolt broke off in there is it ?
don;t know how long its been in there, I put the block in storage 16 years ago.
All I do know is it HAS to come out NOW, or the block is junk (coolant leak)
I did think to half fill the block with block crete and run a manual steering box
first, lets see, if I can get it out
got out the drill and bits,
Humm, that looks like a Tap....%^*
dig at it with a pick, someone before me, beat it and smashed the end, it was off center
couldn't get a tap extractor in there either
checked around, no one had a EDM machine, with a deep enough vat, to burn the tap out..
after looking at it for 2 days, finally got the bore scope and looked behind it.
it was jammed into the #1 cylinder
So I couldn't chisel it, to shatter it
after more thoughts and looking..
Man thats a 5/16 tap in a 3/8 hole....
So, I drilled a 1/8 hole between the 4 fluted tap and the block
after that I could move the tap, as it got to the drilled hole, to popped loose
:blob:
Man, was I so happy,cause We had already ordered crank, rods, and pistons, for that deck height.
WE moved on to studding the block
modding the oil and cooling system,
while waiting on the pistons to be made
Gayle is doing the interior
carpet, seats, head-liner, dash and rear package tray
So,we made it a No door for now, easier to work on
________________________________________________________________________________________________
Ha-Ha Racin
Havin Fun "101"
Gayle and Howard
:blob:
Ha-Ha Racin
Havin Fun "101"
Gayle and Howard
