Nuts and bolts needed.
78kitcar
Cleveland Ohio
I'm in need of the following,
I'm looking for the nut that holds the shock on the rear shock plate.
Also need the nut and bolt that bolts leaf spring to the body there's 4 per mount. i need 2 of them.
also looking for this nut and bolt combo. It holds the 2 collars from a steering column together. There's 2 per column i need 1. Column is from 69 barracuda.
Thanks
No longer need the nut and bolt in the picture. Still searching for the others.
