Odd tach and AFM gremlin...any ideas??
dusterdoug
Tracy, CA
Auto meter tach and A/F meter plugged into the heat/ac fuse...
Have a signal to both when key is the on position. Once car is running I lose the signal to both. But...heater fan still works.
I ran a jumper wire from both direct to the battery and they work as they should.
Could this be a bad ignition switch?? It is a repop, and each worked a couple of weeks ago and now this.
Thoughts??
And thanks in advance!!
I'm not sure I'm following. You are looking for a key on power source? and you tapped into the heat/ac fuse?
There are multiple other sources for key on power under the dash.
I don't think you have a bad ignition switch, I think your source for 12V is a poor one.
If other accessories work it's not the switch. Might just be bad fuse clips, wire connections to them or even a bad fuse
Turns out the new repop ignition switch is bad. When the car is running and I wiggle the key, AFM and tach are live. If I let go of the key, I lose them.
I had planned to move them to the ignition switch itself. That source was a quick plug in just to for the initial start up, timing/carb adjustments, etc...
