Brad5301
Active Member
I stop by a hardware store to get my only ignition key to the Dart duplicated. The knowledgeable lady was doing all sorts of tinkering and called for assistance. “Dave” found my key to be extremely worn down, and a split is visible down the length of the blade.
He taped a modified blank to the original so it would fit in the machine. He made a couple copies at no charge singe he didn’t think they would be successful. He also advised to NOT put the original back in the ignition, for fear of breaking.
I explained the car had low miles (36,000). He said it must have lived in a man’s pocket for years and years. Just wearing out on a ring- i suspect the original owner , who had a primary car.
At home, one key didnt work. The second would allow the ignition to turn but tightly and not enough to engage the starter. I suppose my next step is to take the original; still attached to the modified blank, and the key partially working to a full time locksmith.
Anyone know enough about key smithing to offer advice? Maybe it just needs some fine polishing?
