Odometer Timing
Jim Kueneman
Sonoita, Az
Not sure where the best place to post this is so I’ll try here. Is there a procedure time an odometer to rollover on the transition of the next digit when the previous turns to zero? I had to replace mine as it ate itself. I set the new one to the same mileage and it doesn’t roll over on the 9-0 transition for each digit now.
I played with an odometer from a busted cluster and I could not get it to move correctly after.
It a simple mechanical device but I'm sure it's just an alignment of a part.
BUT WHAT PART!
