I know this subject has been debated before. I also saw the mopar memo describing standard chrome valve covers on the Plymouth Super Commando HP 383. Has anyone seen the Dodge Dart with "orange" valve covers on an hp 383?
???Heads-up! V/covers need to be "disassembled" to be chromed leading to high cost. Just had mine done- $800.
I have several sets of 67, 68, and 69 chrome valve covers, the only problem is they were in my garage fire and are covered with soot. I haven't found anything that takes that stuff off, so they will need rechromed I am pretty sure.
OK, this is a little scary. Talked to two chrome shops and this seems to be standard procedure. Before chroming can begin, all baffles, brackets and tabs must be removed from v/cover. Then straightening and plating can begin. Baffles, brackets and tabs are then re-attached before final plating. Here is the result. These are original v/covers on my '68 cuda 383. The original chrome has been stripped and then re-chromed. Hardly anyone in California is qualified to do this, so I have been using Paul's in Penn. Covers look fantastic, I am very happy, but wanted to post so you know what you are in for. $800.
