[SOLD] OEM Disc Brake Proportioning Valve From The 71-76 A Body Line Of Cars.
hemi71x
hemi71x
Rancho Cordova, CA
Up for sale is disc brake proportioning valve from the A body line of cars. All the valves that i have in stock are with the hard lines for Power Brake applications. The difference is, the lines are longer, than the ones for manual brakes.
This style valve was used from from the 1971 year until into 1976 when the cast iron valve started showing up on the A body cars.
Use this valve on any body style car that your working on, and disc brake system.
$75.00 for the valve with the hard lines. The reason for that is because i don't get these assemblies for free at the wrecking yards when i find them They nickel and dime you to death for every little item, and they charge you for the lines that are attached to the valve. So these parts cost me more money, than just a bare valve, so i have to pass along the cost, or it's just not worth it to sell these things. Still lots cheaper than those China repop ones that don't work, or leak all the time from reports that i have read, about these valves, from aftermarket sellers, vendors
Payment will be thru Pay Pal.
I will FEDEX out to your zip code, and will need your code to give you the shipping quote.
Send me a pm, if your interested, and then we can go from there.
Jim V.
