[FOR SALE] Oem light and ignition switches $25 each shipped
grampscamp
Aldergrove B.C.
All used and working when removed. Shipping price is to the lower 48. Not made in China crap. A few ignition switches have a key.
Pm sent, what I am saying is i don't have a 71 dart or duster, or 67 valiant, or a 68 dodge dart, I have a 66 early A body Plymouth, would like to have a spare ignition switch.
Is there one in you line up of switches..
Ok, thank you, I need the bottom one, looks more like the back of mine. Private conversation stated. Thank you
2497158 is the correct 6 pin switch for '64-7 models. It has a nub on the bottom to lock into the instrument cluster housing. Usually, the earlier 5 pin switch will work too if the ground connection is not needed. The later 6 pin will replace the earlier 5 pin without a problem, in fact, the earlier switch was discontinued and the later one superceded it.
