Oil breather
edbux
Caldwell, Idaho
On stock valve covers from a 67 small block, the oil breather cap has a hose that runs to the air cleaner. Has anyone figured out how to connect the hose to a chrome aftermarket cleaner?
Yep, some aftermarket air-cleaners have a spot for it already. Some dont. Mr.Gasket from what I've seen DO have it...my Edelbrock air cleaner I bought a while ago did NOT.
That's for the PCV valve, isnt it? If the aircleaner doesnt make provision for a connection you can connect to a port on the carby (check carby instructions for correct port), at least I could on the Edelbrock carby I used to have.
I ended up buying an oil breather filter, like the older Fords had. The plastic holder for the filer has a 90 degree bend in it and I drilled a hole in the flat part of the air cleaner base and clip her in. The hose is 5/8" dia, like the heater hose.
