oil dipstick with milodon pan
TheGreatGazoo
New York
what oil dipstick can i use on my 2013 5.7 when im using a milodon pan. my old dipstick went into the pan on the pass side. i knocked out the plug on the drivers side now i need a tube and stick to go in. im looking for a stock style. what vehicle went into the block on the drivers side
thanks for any help
Trucks and SUV used the block mount dipstick tube. Obviously, the length of the stick will need to be calibrated. The handles are pinned on with a tiny roll pin. I remove that, cut it to desired length, re-drill hole, then reinstall handle. I think Milodon, or posibly Lokar, make them as well. I prefer the factory stuff.
Thank you. I prefer the factory tube and stick over the braided hose.
