[Found!] Oil filter adapter
512Stroker
We are all here because we are not all there.
Freedom, MO
I need a P/N and a source for the on the block filter straight/short spin on filter adapter to replace my current 90 degree filter adapter.
1969 LA 340
Thanks
If I recall on my 340 you use the threaded nipple ( where the filter spins on now) off the 90 adapter and you have to get a plate and gasket. Junk yard or parts forum for a factory or this is available.
Canton Racing Products 22-575: Oil Filter Plate SB-Mopar | JEGS
