vallianted
Hey all.can any 90 degree oil filter adapter fit a 65 318 Valliant or does it have to be specific for an early a body.
Thanks for that!All will fit the motor, but only ones for Early A V8 engines will keep the filter from hitting the frame rail. The one on the right in the pic below is the one you need. I will try to get the part # off mine and post it.
Pic credit goes to @65barracudaLA !
That's interesting that you are able to get the big filter to fit. Can you get a pic of how you have the adapter clocked so it all fits? I put a 340 and 727 out of a 73 Dart Sport into a 65 Barracuda that I threw together as a beater years ago. I always liked the 51515 filters, but had to use a little short one because the way the adapter was clocked from the factory on that 340, it hit the frame rail. I didn't want to move the adapter because it wasn't leaking, so I just used a shorty filter.The funny thing is I never new there was a difference between them....I ended up letting my 65 one get away from me and put an aluminum one from a fifth avenue on mine at the moment with big 51515 filter on my 340 in my 64 Valiant....and I got a couple of aluminum ones that look like most common ones (I guess like 67 and up?????).
Is this with the early A one or a newer style?This was my 68 273 Valiant Large K&N. Header photo from top. Large Motorcraft on it.
Well, add me to the list of people who never knew the one on the left even existed. The older I get, the more I find out how much I don't know.All will fit the motor, but only ones for Early A V8 engines will keep the filter from hitting the frame rail. The one on the right in the pic below is the one you need. I will try to get the part # off mine and post it.
