bill detamore
Men
I have an oil leak in an odd place. Backstory
I have 1971 Scamp that has a 318. I had a Performer manifold istalled. Only when I go on the freeway I guess at high RPM's, I have a leak from my valve cover. I get a pool on the topside where the head meets the manifold. If I am going for sometime, I get a bit of oil in the pockets of the manifold. As far as I can see there is no other leaks.
New gaskets were installed when the job was done and I just had new ones installed again but I have the leak in the same spot. There was no leak before but ever since, I have had this issue. Am I right to assume there is not a right and left side on these?
I would love to hear some thoughts on this.
I am also looking for a rocker trim peice for below the door. Any suggestion on where to get it.
Thanks guys.
B
Thanks guys.
B
